Busco Ayuda para Opentel 4150 PVR | archivostv.com
Bienvenido al foro. accede al foro o registrate
foro Archivostv.com
Bienvenidos al foro Archivostv.com
goodluckspain
24 Ene 2006
Tengo un Equipo Receptor de Satelite Opentel 4150 PVR con Hdd de 40 Gb + Matrix Cam Revolutions + Tarjeta Knotcard.
Actualmente con Varios Modelos se vuelve a ver Todo. Necesitaria Saber como puedo Hacerlo para verlo con este Equipo. :confused:
Receptor de satelite Opentel OSD-4150.
Con un disco duro de PC para grabar canales libres o codificados.
2 Entradas de pcmcia (2 CI)
Diseq 1.2
Time Shift Function with a Live Channel
Book Marking Function
Delayed Recording in EPG
Fast Forward / Reverse in Replaying
Recording Capacity:25 hours for 40Mbps Stream with 40GB HDD
S/PDIF for Digital Audio
Fully MPEG-2 & DVB Compliant
2 Slots of Common Interface for Viaccess, Conax, Cryptoworks,
Nagravision, Irdeto, SECA
Input Frequency 950 - 2150 MHz
Supports SCPC & MCPC from C / Ku-band
2 Tuners of 1 LNB input with Loop Through IF Signal
Tuner Symbol Rate : 1~45 MS/s
Fast Booting & Auto Scan
Quick Channel Changing Speed Less than 1 Sec.
Max. 4000 Channels ( TV & Radio) Programmable
User Friendly 256 Colors OSD & Easy GUI
Preprogrammed Channel List Memorable
Various OSD Languages supported
( English, German, French, Russian, Spanish, Italian, Arabic,
Persian, Turkish)
Supports EPG, PIG
Radio Channel Background Display
Favorite Channel List Programmable
Master PIN Code Function & Parental Lock Function
20 Steps Volume Control
Automatic Detection of Forward Error Correction
Automatic NTSC / PAL Detection and Simple Video Converter (NTSC ---
PAL)
Window based S/W Download Program Supported by RS232 Serial Port
Set to Set Download (Main Program, Channel Data)
4:3, 16:9 Letter Box & Teletext using OSD
7 Segment-4 Digit Display
5 Buttons on the Front Panel (Power On/Off, Channel Up/Down, Volume
Up/Down)
Various LNB Polarity Control
- DiSEqC 1.0 & 1.2 with 500mA Max. LNB Power
- 22KHz Switching Control
2 SCART Output for TV & VCR
3 RCA Output for Video, Audio L/R
Wide PLL RF Modulator (PAL B/G, I, D/K)
